Hello, I’m using sonarr for about a year now, along with jackett for fetching torrents and qbittorrent for downloading them.
I have had a great time using it, although there is a thing that I have not figured out.
When torrent has square brackets in it “[ ]”, sonarr is unable to import it.
My workaround is to go to the folder it’s downloaded, remove the brackets, and rename the torrent’s name in qbittorrent in order for Sonarr to try to fetch the file without square brackets and succeed.
It’s working, but it defeats the purpose of automating things.
Is there a setting on sonarr i have missed in order to understand square brackets and be able to import the files itself?
If importing them is not possible, is it possible to somehow ignore torrents that have square brackets altogether so that another torrent without them is found for the requested series?
Example Torrent name with square brackets: El.Chapo.S01E02.1080p.WebRip.x264.[By ExYu-Subs HC]
Thank you in advance!
