I’ve checked the forums to no avail. My error seems to be related to sqlite3.
I’m installing nzbdrone on Ubuntu 14. I followed the install directions on the sonarr site.
I’ve installed and reinstalled everything multiple times.
Ubuntu 14.04 LTS 64-bit
SQLite version 3.8.7.4 2014-12-09 01:34:36
Mono JIT compiler version 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014)
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
When I run mono /opt/NzbDrone/NzbDrone.exe I get:
[Info] Bootstrap: Starting NzbDrone - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.3004
[Debug] ProcessProvider: Found 0 processes with the name: NzbDrone.Console
[Debug] ProcessProvider: Found 1 processes with the name: NzbDrone
[Info] MigrationLogger: *** Migrating data source=/root/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
System.EntryPointNotFoundException: sqlite3_column_database_name
at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods:sqlite3_column_database_name (intptr,int)
at System.Data.SQLite.SQLite3.ColumnDatabaseName (System.Data.SQLite.SQLiteStatement stmt, Int32 index) [0x00000] in :0
at System.Data.SQLite.SQLiteDataReader.GetStatementColumnParents (System.Data.SQLite.SQLiteBase sql, System.Data.SQLite.SQLiteStatement stmt, Int32 fieldCount, System.Collections.Generic.Dictionary2& parentToColumns, System.Collections.Generic.Dictionary
2& columnToParent) [0x00000] in :0
at System.Data.SQLite.SQLiteDataReader.GetSchemaTable (Boolean wantUniqueInfo, Boolean wantDefaultValue) [0x00000] in :0
at System.Data.SQLite.SQLiteDataReader.GetSchemaTable () [0x00000] in :0
at System.Data.Common.DataAdapter.BuildSchema (IDataReader reader, System.Data.DataTable table, SchemaType schemaType, MissingSchemaAction missingSchAction, MissingMappingAction missingMapAction, System.Data.Common.DataTableMappingCollection dtMapping) [0x00000] in :0
at System.Data.Common.DataAdapter.BuildSchema (IDataReader reader, System.Data.DataTable table, SchemaType schemaType) [0x00000] in :0
at System.Data.Common.DataAdapter.FillTable (System.Data.DataTable dataTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords, System.Int32& counter) [0x00000] in :0
at System.Data.Common.DataAdapter.FillInternal (System.Data.DataSet dataSet, System.String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) [0x00000] in :0
at System.Data.Common.DataAdapter.Fill (System.Data.DataSet dataSet, System.String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) [0x00000] in :0
at System.Data.Common.DbDataAdapter.Fill (System.Data.DataSet dataSet, Int32 startRecord, Int32 maxRecords, System.String srcTable, IDbCommand command, CommandBehavior behavior) [0x00000] in :0
at System.Data.Common.DbDataAdapter.Fill (System.Data.DataSet dataSet) [0x00000] in :0
at FluentMigrator.Runner.Processors.SQLite.SqliteProcessor.Read (System.String template, System.Object[] args) [0x00000] in :0
at FluentMigrator.Runner.Processors.SQLite.SqliteProcessor.ColumnExists (System.String schemaName, System.String tableName, System.String columnName) [0x00000] in :0
at FluentMigrator.Runner.VersionLoader.get_AlreadyMadeVersionUnique () [0x00000] in :0
at FluentMigrator.Runner.VersionLoader.LoadVersionInfo () [0x00000] in :0
at FluentMigrator.Runner.VersionLoader…ctor (IMigrationRunner runner, System.Reflection.Assembly assembly, IMigrationConventions conventions) [0x00000] in :0
at FluentMigrator.Runner.MigrationRunner…ctor (System.Reflection.Assembly assembly, IRunnerContext runnerContext, IMigrationProcessor processor) [0x00000] in :0
at NzbDrone.Core.Datastore.Migration.Framework.MigrationController.MigrateToLatest (System.String connectionString, MigrationType migrationType, System.Action1 beforeMigration) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Datastore.DbFactory.Create (MigrationType migrationType, System.Action
1 beforeMigration) [0x00000] in :0
at NzbDrone.Core.Datastore.DbFactory.RegisterDatabase (IContainer container) [0x00000] in :0
at NzbDrone.Host.Bootstrap.Start (ApplicationModes applicationModes, NzbDrone.Common.EnvironmentInfo.StartupContext startupContext) [0x00000] in :0
at NzbDrone.Host.Bootstrap.Start (NzbDrone.Common.EnvironmentInfo.StartupContext startupContext, IUserAlert userAlert, System.Action`1 startCallback) [0x00000] in :0
at NzbDrone.Console.ConsoleApp.Main (System.String[] args) [0x00000] in :0
Press any key to exit…
Help would be much appreciated. I’ve heard great things about sonarr.
