Getting this error after the latest update:
System.EntryPointNotFoundException: sqlite3_column_database_name
at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods:sqlite3_column_database_name (intptr,int)
at System.Data.SQLite.SQLite3.ColumnDatabaseName (System.Data.SQLite.SQLiteStatement stmt, Int32 index) [0x00000] in <filename unknown>:0
at System.Data.SQLite.SQLiteDataReader.GetStatementColumnParents (System.Data.SQLite.SQLiteBase sql, System.Data.SQLite.SQLiteStatement stmt, Int32 fieldCount, System.Collections.Generic.Dictionary`2& parentToColumns, System.Collections.Generic.Dictionary`2& columnToParent) [0x00000] in <filename unknown>:0
at System.Data.SQLite.SQLiteDataReader.GetSchemaTable (Boolean wantUniqueInfo, Boolean wantDefaultValue) [0x00000] in <filename unknown>:0
at System.Data.SQLite.SQLiteDataReader.GetSchemaTable () [0x00000] in <filename unknown>:0
at System.Data.Common.DataAdapter.BuildSchema (IDataReader reader, System.Data.DataTable table, SchemaType schemaType, MissingSchemaAction missingSchAction, MissingMappingAction missingMapAction, System.Data.Common.DataTableMappingCollection dtMapping) [0x0003b] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DataAdapter.cs:249
at System.Data.Common.DataAdapter.BuildSchema (IDataReader reader, System.Data.DataTable table, SchemaType schemaType) [0x00000] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DataAdapter.cs:222
at System.Data.Common.DataAdapter.FillTable (System.Data.DataTable dataTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords, System.Int32& counter) [0x00011] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DataAdapter.cs:393
at System.Data.Common.DataAdapter.FillInternal (System.Data.DataSet dataSet, System.String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) [0x0009b] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DataAdapter.cs:496
at System.Data.Common.DataAdapter.Fill (System.Data.DataSet dataSet, System.String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) [0x00000] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DataAdapter.cs:551
at System.Data.Common.DbDataAdapter.Fill (System.Data.DataSet dataSet, Int32 startRecord, Int32 maxRecords, System.String srcTable, IDbCommand command, CommandBehavior behavior) [0x0004e] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DbDataAdapter.cs:293
at System.Data.Common.DbDataAdapter.Fill (System.Data.DataSet dataSet) [0x00000] in /private/tmp/mono20150717-46061-1r9ir61/mono-4.0.2/mcs/class/System.Data/System.Data.Common/DbDataAdapter.cs:234
at FluentMigrator.Runner.Processors.SQLite.SqliteProcessor.Read (System.String template, System.Object[] args) [0x00032] in c:\Community\schambers\fluentmigrator\src\FluentMigrator.Runner\Processors\SQLite\SqliteProcessor.cs:197
at FluentMigrator.Runner.Processors.SQLite.SqliteProcessor.ColumnExists (System.String schemaName, System.String tableName, System.String columnName) [0x00000] in c:\Community\schambers\fluentmigrator\src\FluentMigrator.Runner\Processors\SQLite\SqliteProcessor.cs:52
at FluentMigrator.Runner.VersionLoader.get_AlreadyMadeVersionUnique () [0x00000] in c:\Community\schambers\fluentmigrator\src\FluentMigrator.Runner\VersionLoader.cs:119
at FluentMigrator.Runner.VersionLoader.LoadVersionInfo () [0x00050] in c:\Community\schambers\fluentmigrator\src\FluentMigrator.Runner\VersionLoader.cs:154
at FluentMigrator.Runner.VersionLoader..ctor (IMigrationRunner runner, System.Reflection.Assembly assembly, IMigrationConventions conventions) [0x00077] in c:\Community\schambers\fluentmigrator\src\FluentMigrator.Runner\VersionLoader.cs:43
at FluentMigrator.Runner.MigrationRunner..ctor (System.Reflection.Assembly assembly, IRunnerContext runnerContext, IMigrationProcessor processor) [0x000d6] in c:\Community\schambers\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:87
at NzbDrone.Core.Datastore.Migration.Framework.MigrationController.MigrateToLatest (System.String connectionString, MigrationType migrationType, System.Action`1 beforeMigration) [0x0007f] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\Migration\Framework\MigrationController.cs:40
at NzbDrone.Core.Datastore.DbFactory.Create (MigrationType migrationType, System.Action`1 beforeMigration) [0x00049] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\DbFactory.cs:69
at NzbDrone.Core.Datastore.DbFactory.RegisterDatabase (IContainer container) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\DbFactory.cs:31
at NzbDrone.Host.Bootstrap.Start (ApplicationModes applicationModes, NzbDrone.Common.EnvironmentInfo.StartupContext startupContext) [0x0002e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Host\Bootstrap.cs:69
at NzbDrone.Host.Bootstrap.Start (NzbDrone.Common.EnvironmentInfo.StartupContext startupContext, IUserAlert userAlert, System.Action`1 startCallback) [0x00070] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Host\Bootstrap.cs:38
at NzbDrone.Console.ConsoleApp.Main (System.String[] args) [0x0000f] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Console\ConsoleApp.cs:20
Did some searching and found that it may be a sqlite3 error. my sqlite3 version is: 3.8.10.2
any idea what is going on?
