Mono version (if Sonarr is not running on Windows): ??
OS: Win10
Description of issue: I was able to edit the Standard Episode Format to remove the spaces so the file downloaded has no spaces to the right of the Series Title. But often the {Series Title} has spaces instead of periods or underscores for spaces. Is there a way to correct that in the Episode Naming fields? I am a newbie to Sonarr… After I published this a post came back about using {Series.CleanTitle}. Although the help didn’t show that I could use a “.” period in the lable or tag or whatever that is called. Hopefully that will work.
