Quick question.
Just added iZombie to NzbDrone, but it is sorting it under Z instead if I.
Why does it do that please?
How do you add images to posts ??
Link to image: https://dl.dropboxusercontent.com/u/8367652/Capture899.jpg
Quick question.
Actually, it’s sorting under ‘i’ lowercase. Tnx for the report. I’ll probably change the sort logic to be case-insensitive.
Thanks Taloth.
Just an extra to this request, and I apologise if this is already being dealt with, but can the word “The” be ignored when sorting/displaying TV shows please.
For example, The big Bang theory is listed under ‘T’ instead of ‘B’.
Lots of other apps/services already ignore “The” when displaying show names, so could NzbDrone do the same please.
Or is there a setting already in place that I haven’t come across as yet ??
Thanks in advance.
This is already being worked on (https://trello.com/c/9fGfPjpy/196-ignore-articles-when-sorting), though there is one piece of it we need to fix.
OK, thanks Markus.
I see that “the” is being ignored in TV series lists sorting and that case-sensitive sorting is now working in the latest dev build - many thanks.
