Hi.
I’m currently using a setup of Sonarr on an Oracle virtualbox Virtual Machine running Windows 7 with Deluge.
Local hard drives on the host machine are added in through virtualbox, set up to automount, and appear in the virtual machine as network drives.
This has worked for months with no issues as the network drives listed as root directories (Aimed directly at directories containing series).
Recently, however, Sonarr is throwing errors of “cannot check disk space” and fails to import episodes once downloaded.
Several restarts have been attempted, to no avail.
The VM can see and access the drives perfectly fine- I can manually copy and paste the episodes with no issue.
Sonarr is set to startup on windows start via a link in the startup folder.
Attempting to re-add the network drive results in Sonarr claiming the “Path does not exist”.
This was working previous with the path of “J:”
Nothing on the system is changed, but this issue permanently disables importing episodes, largely defeating the point.
Has anyone dealt with this? Any workarounds?
Logs below:
ComponentMessage TimeImportApprovedEpisodesCouldn't
import episode
C:\Users\zoidburg\Downloads\Brooklyn.Nine-Nine.S03E03.HDTV.x264-FUM[ettv]\Brooklyn.Nine-Nine.S03E03.INTERNAL.HDTV.x264-FUM[ettv].mp4:
Root folder ‘I:’ was not found.6:12pmFreeSpaceSpecificationUnable to check free disk space while importing. I:\6:12pmImportApprovedEpisodesCouldn’t
import episode
C:\Users\zoidburg\Downloads\Haven.S05E14.REPACK.HDTV.x264-KILLERS[rarbg]\Haven.S05E14.REPACK.HDTV.x264-KILLERS.mp4:
import episode
C:\Users\zoidburg\Downloads\The.Flash.2014.S02E01.The.Man.Who.Saved.Central.City.WEB-DL.x264.AAC\The.Flash.2014.S02E01.The.Man.Who.Saved.Central.City.WEB-DL.x264.AAC.mp4:
import episode
C:\Users\zoidburg\Downloads\The.Big.Bang.Theory.S09E04.The.2003.Approximation.WEB-DL.x264.AAC\The.Big.Bang.Theory.S09E04.The.2003.Approximation.WEB-DL.x264.AAC.mp4:
import episode
C:\Users\zoidburg\Downloads\Limitless.S01E04.HDTV.x264-LOL[rarbg]\limitless.104.hdtv-lol.mp4:
Root folder ‘H:’ was not found.6:12pmFreeSpaceSpecificationUnable to check free disk space while importing. H:\6:12pmRssSyncServiceStarting RSS Sync6:12pmDiskSpaceServiceUnable to get free space for: J:: J:\6:12pmDiskSpaceServiceUnable to get free space for: I:: I:\6:12pmDiskSpaceServiceUnable to get free space for: J:: J:\6:12pmDiskSpaceServiceUnable to get free space for: H:: H:\6:12pmDiskSpaceServiceUnable to get free space for: I:: I:\6:12pmDiskSpaceServiceUnable to get free space for: H:: H:\6:12pm
