Thanks, i think i have that sorted. Since deleting the Bin folder and installing again, Sonarr doesnt actually have a tray icon but because the Web UI is working as expected, would i be right to assume that this is okay?
When Sonarr is running as a service you won’t see a tray icon, so yes, perfectly normal.
Thanks, Was just a little worried as i used to have a tray icon. Thanks for all your help!
Is there a way to force Sonarr to check Utorrent for a completed download? There is a 100% finished item in uTorrent and the completed media is in the correct folder. Sonarr used to automatically clear it from Utorrent and then move it and rename it to the TV show folder. Is there a way i can force this or troubleshoot this? All settings seem to be correct and as per how they were when all was working.
Thanks
