Sonarr won't start after reboot
Sonarr has been running fine for weeks as a service on a Win 8 PC but after a reboot earlier today it will no longer start either automatically/manually (service) or by running the exe. I’ve tried uninstalling and reinstalling but the problem continues. After attempting to start the service the last lines in the log are always
15-9-2 23:54:19.2|Info|Router|Application mode: Service
15-9-2 23:54:19.2|Debug|Router|Service selected
15-9-2 23:54:19.2|Info|OwinHostController|Listening on the following URLs:
15-9-2 23:54:19.2|Info|OwinHostController| http://*:8989/
15-9-2 23:54:19.3|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
15-9-2 23:54:19.3|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
15-9-2 23:54:19.3|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
15-9-2 23:54:19.4|Info|NancyBootstrapper|Starting NzbDrone API
15-9-2 23:54:19.4|Trace|EventAggregator|Publishing ApplicationStartedEvent
Any ideas?
Do you see anything else if you run NzbDrone.Console.exe directly?
TinyIoC.TinyIoCResolutionException: Unable to resolve type: NzbDrone.Core.Messag
ing.Events.IHandle1[[NzbDrone.Core.Lifecycle.ApplicationStartedEvent, NzbDrone. Core, Version=2.0.0.3357, Culture=neutral, PublicKeyToken=null]] ---> TinyIoC.Ti nyIoCResolutionException: Unable to resolve type: NzbDrone.Core.Notifications.No tificationFactory ---> TinyIoC.TinyIoCResolutionException: Unable to resolve typ e: NzbDrone.Core.Notifications.INotification ---> TinyIoC.TinyIoCResolutionExcep tion: Unable to resolve type: NzbDrone.Core.Notifications.Growl.Growl ---> TinyI oC.TinyIoCResolutionException: Unable to resolve type: NzbDrone.Core.Notificatio ns.Growl.IGrowlService ---> TinyIoC.TinyIoCResolutionException: Unable to resolv e type: NzbDrone.Core.Notifications.Growl.GrowlService ---> System.TypeInitializ ationException: The type initializer for 'Growl.CoreLibrary.BinaryData' threw an exception. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: T his implementation is not part of the Windows Platform FIPS validated cryptograp hic algorithms. at System.Security.Cryptography.MD5CryptoServiceProvider..ctor() --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, B inder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Obje ct[] args) at System.Security.Cryptography.MD5.Create() at Growl.CoreLibrary.BinaryData..cctor() --- End of inner exception stack trace --- at Growl.CoreLibrary.BinaryData.GenerateID(Byte[] data) at NzbDrone.Core.Notifications.Growl.GrowlService..ctor(Logger logger) in m:\ BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Growl\GrowlServ ice.cs:line 78 at lambda_method(Closure , Object[] ) at TinyIoC.TinyIoCContainer.ConstructType(Type requestedType, Type implementa tionType, ConstructorInfo constructor, NamedParameterOverloads parameters, Resol veOptions options) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Ti nyIoC.cs:line 3677 --- End of inner exception stack trace --- at TinyIoC.TinyIoCContainer.ConstructType(Type requestedType, Type implementa tionType, ConstructorInfo constructor, NamedParameterOverloads parameters, Resol veOptions options) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Ti nyIoC.cs:line 3684 at TinyIoC.TinyIoCContainer.SingletonFactory.GetObject(Type requestedType, Ti nyIoCContainer container, NamedParameterOverloads parameters, ResolveOptions opt ions) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 2834 at TinyIoC.TinyIoCContainer.ResolveInternal(TypeRegistration registration, Na medParameterOverloads parameters, ResolveOptions options) in m:\BuildAgent\work\ 6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 3348 at TinyIoC.TinyIoCContainer.Resolve(Type resolveType, String name) in m:\Buil dAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 1486 at NzbDrone.Common.Composition.Container.<>c__DisplayClass4.<CreateSingletonI mplementationFactory>b__3(TinyIoCContainer c, NamedParameterOverloads p) in m:\B uildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Composition\Container.cs:lin e 80 at TinyIoC.TinyIoCContainer.DelegateFactory.GetObject(Type requestedType, Tin yIoCContainer container, NamedParameterOverloads parameters, ResolveOptions opti ons) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 2543 --- End of inner exception stack trace --- at TinyIoC.TinyIoCContainer.DelegateFactory.GetObject(Type requestedType, Tin yIoCContainer container, NamedParameterOverloads parameters, ResolveOptions opti ons) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 2547 at TinyIoC.TinyIoCContainer.ResolveInternal(TypeRegistration registration, Na medParameterOverloads parameters, ResolveOptions options) in m:\BuildAgent\work\ 6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 3348 at TinyIoC.TinyIoCContainer.ConstructType(Type requestedType, Type implementa tionType, ConstructorInfo constructor, NamedParameterOverloads parameters, Resol veOptions options) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Ti nyIoC.cs:line 3652 --- End of inner exception stack trace --- at TinyIoC.TinyIoCContainer.ConstructType(Type requestedType, Type implementa tionType, ConstructorInfo constructor, NamedParameterOverloads parameters, Resol veOptions options) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Ti nyIoC.cs:line 3665 at TinyIoC.TinyIoCContainer.SingletonFactory.GetObject(Type requestedType, Ti nyIoCContainer container, NamedParameterOverloads parameters, ResolveOptions opt ions) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 2834 at TinyIoC.TinyIoCContainer.ResolveInternal(TypeRegistration registration, Na medParameterOverloads parameters, ResolveOptions options) in m:\BuildAgent\work\ 6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 3348 at TinyIoC.TinyIoCContainer.Resolve(Type resolveType, String name) in m:\Buil dAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 1486 at NzbDrone.Common.Composition.Container.<>c__DisplayClass4.<CreateSingletonI mplementationFactory>b__3(TinyIoCContainer c, NamedParameterOverloads p) in m:\B uildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Composition\Container.cs:lin e 80 at TinyIoC.TinyIoCContainer.DelegateFactory.GetObject(Type requestedType, Tin yIoCContainer container, NamedParameterOverloads parameters, ResolveOptions opti ons) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 2543 --- End of inner exception stack trace --- at TinyIoC.TinyIoCContainer.DelegateFactory.GetObject(Type requestedType, Tin yIoCContainer container, NamedParameterOverloads parameters, ResolveOptions opti ons) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 2547 at TinyIoC.TinyIoCContainer.ResolveInternal(TypeRegistration registration, Na medParameterOverloads parameters, ResolveOptions options) in m:\BuildAgent\work\ 6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:line 3348 at TinyIoC.TinyIoCContainer.<ResolveAllInternal>b__43(TypeRegistration regist ration) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\TinyIoC.cs:li ne 3766 at System.Linq.Enumerable.WhereSelectEnumerableIterator2.MoveNext()
at System.Linq.Enumerable.d__b11.MoveNext() at System.Collections.Generic.List1…ctor(IEnumerable1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable1 source)
nyIoC.cs:line 3677
nyIoC.cs:line 3684
2834
at NzbDrone.Common.Composition.Container.<>c__DisplayClass4.b__3(TinyIoCContainer c, NamedParameterOverloads p) in m:\B
e 80
2543
2547
at TinyIoC.TinyIoCContainer.b__43(TypeRegistration regist
ne 3766
at System.Linq.Enumerable.WhereSelectEnumerableIterator2.MoveNext() at System.Linq.Enumerable.<CastIterator>d__b11.MoveNext()
at System.Linq.Lookup2.Create[TSource](IEnumerable1 source, Func2 keySelec tor, Func2 elementSelector, IEqualityComparer1 comparer) at System.Linq.GroupedEnumerable3.GetEnumerator()
at System.Linq.Enumerable.WhereSelectEnumerableIterator2.MoveNext() at NzbDrone.Core.Messaging.Events.EventAggregator.PublishEvent[TEvent](TEvent event) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Event s\EventAggregator.cs:line 51 at NzbDrone.Api.NancyBootstrapper.ApplicationStartup(TinyIoCContainer contain er, IPipelines pipelines) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Ap i\NancyBootstrapper.cs:line 37 at Nancy.Bootstrapper.NancyBootstrapperBase1.Initialise()
at Nancy.Owin.NancyMiddleware.UseNancy(NancyOptions options)
at Owin.AppBuilderExtensions.UseNancy(IAppBuilder builder, NancyOptions optio
ns)
at NzbDrone.Host.Owin.MiddleWare.NancyMiddleWare.Attach(IAppBuilder appBuilde
r) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Host\Owin\MiddleWare\Nanc
yMiddleWare.cs:line 20
at NzbDrone.Host.Owin.OwinAppFactory.BuildApp(IAppBuilder appBuilder) in m:\B
uildAgent\work\6c3239faf2b92630\src\NzbDrone.Host\Owin\OwinServiceProvider.cs:li
ne 78
at Microsoft.Owin.Hosting.Engine.HostingEngine.ResolveApp(StartContext contex
t)
at Microsoft.Owin.Hosting.Engine.HostingEngine.Start(StartContext context)
at NzbDrone.Host.Owin.OwinAppFactory.CreateApp(List1 urls) in m:\BuildAgent\ work\6c3239faf2b92630\src\NzbDrone.Host\Owin\OwinServiceProvider.cs:line 52 at NzbDrone.Host.Owin.OwinHostController.StartServer() in m:\BuildAgent\work\ 6c3239faf2b92630\src\NzbDrone.Host\Owin\OwinHostController.cs:line 56 at NzbDrone.Host.NzbDroneServiceFactory.Start() in m:\BuildAgent\work\6c3239f af2b92630\src\NzbDrone.Host\ApplicationServer.cs:line 55 at NzbDrone.Host.Router.Route(ApplicationModes applicationModes) in m:\BuildA gent\work\6c3239faf2b92630\src\NzbDrone.Host\Router.cs:line 38 at NzbDrone.Host.Bootstrap.Start(ApplicationModes applicationModes, StartupCo ntext startupContext) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Host\B ootstrap.cs:line 70 at NzbDrone.Host.Bootstrap.Start(StartupContext startupContext, IUserAlert us erAlert, Action1 startCallback) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbD
rone.Host\Bootstrap.cs:line 38
at NzbDrone.Console.ConsoleApp.Main(String[] args) in m:\BuildAgent\work\6c32
39faf2b92630\src\NzbDrone.Console\ConsoleApp.cs:line 20
I fixed the issue by disabling FIPS in Local Security Policy. I suspect it might have been enabled when I installed Cisco Anyconnect VPN client.
Thanks
