I’m also having a problem starting my server. Here’s the log output:
~ ❯ mono --debug /Applications/Sonarr.app/Contents/MacOS/nzbdrone.exe
[Info] Bootstrap: Starting NzbDrone - /Applications/Sonarr.app/Contents/MacOS/nzbdrone.exe - Version 2.0.0.3004
[Debug] ProcessProvider: Found 0 processes with the name: NzbDrone.Console
[Info] MigrationLogger: *** Migrating data source=/Users/dannypeck/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Truncate;pooling=True;version=3 ***
[Debug] MigrationLogger: Took: 00:00:01.5132585
[Info] MigrationLogger: *** Migrating data source=/Users/dannypeck/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Truncate;pooling=True;version=3 ***
System.Data.SQLite.SQLiteException: database disk image is malformed
at System.Data.SQLite.SQLite3.Prepare (System.Data.SQLite.SQLiteConnection cnn, System.String strSql, System.Data.SQLite.SQLiteStatement previous, UInt32 timeoutMS, System.String& strRemain) [0x00000] in :0
at System.Data.SQLite.SQLiteCommand.BuildNextCommand () [0x00000] in :0
Press any key to exit…
