Hi All,
I’m still continuing to have the same issue, where - after upgrading (did so twice with the two master build updates in the last 2 days) - the install works perfectly, and after the upgrade, Sonarr continues to run perfectly.
However, if I shutdown Sonarr and then re-run it from the app (or reboot), then Sonarr will not run again. I need to re-install it from a fresh download.
This isn’t absolutely urgent, but I’d love to solve it. Anyone have a similar issue and find a solution?
Jon
