Sonarr won't fetch torrents for old shows
SONARR VERSION: 2.0.0.4645
OS: Windows 10
Debug log: https://pastebin.com/vkbiM6KR
Hey guys,
I’m encountering some weird behavior with how Sonarr handles some shows. For some reason when I use Sonarr to find torrents (I use BTN) for a handful of shows (I’ve tried Curb your Enthusiasm, Mad Men, and Martin), it won’t find certain seasons. In the log I posted above, I tried to get Sonarr to grab all the seasons of Martin, but it only found and began downloading seasons 1 and 5.
I’ve noticed that this only seems to happen with shows that aren’t currently airing. Every show I’ve added that is still on the air has worked perfectly.
Thanks for your time.
For Martin they are being rejected (one result and it’s rejected):
17-4-3 21:24:15.2|Debug|NzbSearchService|Total of 1 reports were found for [Martin : S04] from 1 indexers
17-4-3 21:24:15.2|Info|DownloadDecisionMaker|Processing 1 releases
17-4-3 21:24:15.2|Debug|Parser|Parsing string 'Martin.S04.Unknown.XViD-NOGRP'
17-4-3 21:24:15.2|Debug|Parser|Episode Parsed. Martin - Season 04
17-4-3 21:24:15.2|Debug|Parser|Language parsed: English
17-4-3 21:24:15.2|Debug|QualityParser|Trying to parse quality for Martin.S04.Unknown.XViD-NOGRP
17-4-3 21:24:15.3|Debug|Parser|Quality parsed: Unknown v1
17-4-3 21:24:15.3|Debug|Parser|Release Group parsed: NOGRP
17-4-3 21:24:15.3|Debug|AcceptableSizeSpecification|Beginning size check for: Martin.S04.Unknown.XViD-NOGRP
17-4-3 21:24:15.3|Debug|AcceptableSizeSpecification|Item: Martin.S04.Unknown.XViD-NOGRP, meets size constraints.
17-4-3 21:24:15.3|Debug|FullSeasonSpecification|Checking if all episodes in full season release have aired. Martin.S04.Unknown.XViD-NOGRP
17-4-3 21:24:15.3|Debug|LanguageSpecification|Checking if report meets language requirements. English
17-4-3 21:24:15.3|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Martin.S04.Unknown.XViD-NOGRP
17-4-3 21:24:15.3|Debug|ReleaseRestrictionsSpecification|[Martin.S04.Unknown.XViD-NOGRP] No restrictions apply, allowing
17-4-3 21:24:15.3|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. Unknown v1
17-4-3 21:24:15.3|Debug|QualityAllowedByProfileSpecification|Quality Unknown v1 rejected by Series' quality profile
17-4-3 21:24:15.3|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
17-4-3 21:24:15.3|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
17-4-3 21:24:15.3|Debug|SeriesSpecification|Checking if series matches searched series
17-4-3 21:24:15.3|Debug|DelaySpecification|Ignoring delay for user invoked search
17-4-3 21:24:15.3|Debug|HistorySpecification|Skipping history check during search
17-4-3 21:24:15.3|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Unknown is not wanted in profile
Rejected because there isn’t a known quality in the release name and unknown qualities aren’t wanted by default. Doing a manual search will show season packs from BTN (only BTN currently) and you can force Sonarr to grab it.
