Mono version (if Sonarr is not running on Windows): 5.18.0.268
OS: MacOS 10.14.3
Debug logs: https://pastebin.com/MatdFit7
Description of issue: I’ve been happily using Sonarr and Transmission, but yesterday did a full HD wipe and a clean install to upgrade from macOS Sierra to Mojave. I went about setting up Sonarr again, but it can’t seem to connect to Transmission. When I try to add the download client and test the connection it is unable to connect to the “host: localhost”. I tried replacing that with my IP address, but the same thing happens. I’ve also tried a different download client (Deluge) but the same problem occurs. Any ideas?
Can you access transmission from a browser?
Ah, I didn’t have Remote Access enabled! Thanks for pointing me in the right direction. Problem solved
