Sonarr won't Autostart after Update and strange message
I decided to update to the latest version of Sonarr through the GUI and everything went ok. Now Sonarr won’t autostart and I am getting this strange message when I boot my mac. To be fair I am not sure if this is directly related to Sonarr as I have no idea what is causing this message or why its coming up. It may be a coincidence it appeared after the update.
Any help would be appreciated.
google says that this is a developers message and it appears if an app is crashing. I may be wrong but i assume that Sonarr is not loading properly and you get this message.
Yes, I updated yesterday and when I boot the computer and start safari sonarr won’t load. Don’t know if its crashing though. I clicked the updates tab after I got it too load manually and I seen the message next to the latest sonarr “install.” I have done that and it now says installed so I’ll keep an eye on it to see if that did the trick. I couldn’t find much on the lldb command message other than installation instructions. I’m not going to install until I know what it’s for and what program needs/wants it.
Hopefully the above will stop the message coming back.
