hello, I’m running the latest version of Sonarr on Windows 10 and am having issues auto downloading. It won’t grab anything over 250 mb automatically, that’s what the red exclamation point says is the issue when I do a manual search. I have my quality settings set to 400mb for 1/2 hour videos so I don’t know why it won’t grab them above 250 for any quality or length. Any advise would be much appreciated.
Thank you.
for the size limit of a quality there should be four values displayed
- minimum size for a 30 minute ep (left, orange)
- minimum size for a 60 minute ep (left, blue)
- maximum size for a 30 minute ep (right, orange)
- maximum size for a 60 minute ep (right, blue)
what do yours have for the quality its trying to download?
Also, did you by any chance set the global maximum size in the Indexers tab?
Thanks for this! Yes it was an issue with having the limit set in the indexers to 250 mb which I’ve now changed
I also download mainly 720 shows since I’m using a rpi3b+ as my server and can’t handle high bit rates, although my highest bitrate movie rn is around 9mb/s and I can stream that flawlessly even away from my home network
Does anyone have quality size suggestions for a rpi3b+ Server? I would like to download good quality and make sure it can still stream with direct play on plex.
Thank you
