Sonarr Ver. 2.0.0.4613
Windows 10 pro
I can add log files, but looking at them everything seems fine.
Description:
So I am loving sonarr but I’m a bit lost with this issue. If I add a series using the Series -> Add Series and typing it all in by hand then the episodes will download and move correctly (they will also get assigned the tv-sonarr category and will show up in Activity)
If I added the series via “Import Existing Series on disk” then the series will autodownload on qbittorent (like above) but it WONT automove to its folder and it also wont show up in Activity or the tv-sonarr category).
Did I not set something correctly? Any help would be appreciated so I don’t have to add all of these series by hand.
