Sonarr will not start properly error "Database is Locked" UBUNTU
Hello.
I am having issues accessing Sonarr by the web interface further investigation of the debug shown the following
mono --debug NzbDrone.exe
[Info] Bootstrap: Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.3357
[Debug] ProcessProvider: Found 0 processes with the name: NzbDrone.Console
[Debug] ProcessProvider: Found 1 processes with the name: NzbDrone
[Debug] ProcessProvider:  - [13944] NzbDrone
[Info] MigrationLogger: *** Migrating data source=/home/jonesd/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Debug] MigrationLogger: Took: 00:00:00.1751286
[Info] MigrationLogger: *** Migrating data source=/home/jonesd/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Debug] MigrationLogger: Took: 00:00:00.0109153
[Debug] Router: Console selected
[Info] OwinHostController:   http://*:2010/
[Debug] OwinAppFactory: Attaching NzbDroneVersionMiddleWare to host
[Debug] OwinAppFactory: Attaching SignalRMiddleWare to host
[Debug] OwinAppFactory: Attaching NancyMiddleWare to host
[Info] NancyBootstrapper: Starting NzbDrone API
[Trace] EventAggregator: Publishing ApplicationStartedEvent
[Trace] EventAggregator: ApplicationStartedEvent -> UserService
[Trace] EventAggregator: ApplicationStartedEvent <- UserService
[Trace] EventAggregator: ApplicationStartedEvent -> DownloadClientFactory
[Debug] DownloadClientFactory: Initializing Providers. Count 9
[Trace] EventAggregator: ApplicationStartedEvent <- DownloadClientFactory
[Trace] EventAggregator: ApplicationStartedEvent -> IndexerFactory
[Debug] IndexerFactory: Initializing Providers. Count 14
[Trace] EventAggregator: ApplicationStartedEvent <- IndexerFactory
[Trace] EventAggregator: ApplicationStartedEvent -> ReconfigureLogging
[Error] EventAggregator: TaskManager failed while processing [ApplicationStartedEvent]
System.Data.SQLite.SQLiteException: database is locked
database is locked
  at System.Data.SQLite.SQLite3.Step (System.Data.SQLite.SQLiteStatement stmt) [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteDataReader.NextResult () [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteDataReader..ctor (System.Data.SQLite.SQLiteCommand cmd, CommandBehavior behave) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteDataReader:.ctor (System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior)
  at System.Data.SQLite.SQLiteCommand.ExecuteReader (CommandBehavior behavior) [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery (CommandBehavior behavior) [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery () [0x00000] in <filename unknown>:0
  at Marr.Data.QGen.UpdateQueryBuilder`1[NzbDrone.Core.Jobs.ScheduledTask].Execute () [0x0003b] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\QGen\UpdateQueryBuilder.cs:157
  at Marr.Data.DataMapper.Update[ScheduledTask] (NzbDrone.Core.Jobs.ScheduledTask entity, System.Linq.Expressions.Expression`1 filter) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\DataMapper.cs:674
  at NzbDrone.Core.Datastore.BasicRepository`1[NzbDrone.Core.Jobs.ScheduledTask].Update (NzbDrone.Core.Jobs.ScheduledTask model) [0x0002b] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\BasicRepository.cs:131
  at NzbDrone.Core.Datastore.BasicRepository`1[NzbDrone.Core.Jobs.ScheduledTask].Upsert (NzbDrone.Core.Jobs.ScheduledTask model) [0x00019] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\BasicRepository.cs:192
  at NzbDrone.Core.Jobs.TaskManager.Handle (NzbDrone.Core.Lifecycle.ApplicationStartedEvent message) [0x002ff] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Jobs\TaskManager.cs:110
  at NzbDrone.Core.Messaging.Events.EventAggregator.PublishEvent[ApplicationStartedEvent] (NzbDrone.Core.Lifecycle.ApplicationStartedEvent event) [0x000c5] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Events\EventAggregator.cs:56
[Error] EventAggregator: CommandQueueManager failed while processing [ApplicationStartedEvent]
database is locked
  at Marr.Data.DataMapper.ExecuteNonQuery (System.String sql) [0x0002a] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\DataMapper.cs:204
  at NzbDrone.Core.Messaging.Commands.CommandRepository.OrphanStarted () [0x00064] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Commands\CommandRepository.cs:46
  at NzbDrone.Core.Messaging.Commands.CommandQueueManager.Handle (NzbDrone.Core.Lifecycle.ApplicationStartedEvent message) [0x00010] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Commands\CommandQueueManager.cs:209
[Error] TaskExtensions: Task Error
database is locked
at System.Data.SQLite.SQLite3.Step (System.Data.SQLite.SQLiteStatement) <IL 0x0009f, 0x0026b>
at System.Data.SQLite.SQLiteDataReader.NextResult () <IL 0x00172, 0x006c6>
at System.Data.SQLite.SQLiteDataReader..ctor (System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior) <IL 0x00091, 0x00299>
at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteDataReader..ctor (System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior) <IL 0x0001b, 0x00047>
at System.Data.SQLite.SQLiteCommand.ExecuteReader (System.Data.CommandBehavior) <IL 0x0000e, 0x00043>
at System.Data.SQLite.SQLiteCommand.ExecuteScalar (System.Data.CommandBehavior) <IL 0x0000c, 0x00037>
at System.Data.SQLite.SQLiteCommand.ExecuteScalar () <IL 0x00008, 0x0001f>
at Marr.Data.QGen.InsertQueryBuilder`1<NzbDrone.Core.Messaging.Commands.CommandModel>.Execute () <0x000d3>
at Marr.Data.DataMapper.Insert<NzbDrone.Core.Messaging.Commands.CommandModel> (NzbDrone.Core.Messaging.Commands.CommandModel) <0x00144>
at NzbDrone.Core.Datastore.BasicRepository`1<NzbDrone.Core.Messaging.Commands.CommandModel>.Insert (NzbDrone.Core.Messaging.Commands.CommandModel) <0x00071>
at NzbDrone.Core.Messaging.Commands.CommandQueueManager.Push<NzbDrone.Core.Download.CheckForFinishedDownloadCommand> (NzbDrone.Core.Download.CheckForFinishedDownloadCommand,NzbDrone.Core.Messaging.Commands.CommandPriority,NzbDrone.Core.Messaging.Commands.CommandTrigger) <0x004e1>
at (wrapper dynamic-method) object.CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,NzbDrone.Core.Messaging.Commands.CommandQueueManager,object,NzbDrone.Core.Messaging.Commands.CommandPriority,NzbDrone.Core.Messaging.Commands.CommandTrigger) <IL 0x0005d, 0x000f6>
at System.Dynamic.UpdateDelegates.UpdateAndExecute4<NzbDrone.Core.Messaging.Commands.CommandQueueManager, object, NzbDrone.Core.Messaging.Commands.CommandPriority, NzbDrone.Core.Messaging.Commands.CommandTrigger, object> (System.Runtime.CompilerServices.CallSite,NzbDrone.Core.Messaging.Commands.CommandQueueManager,object,NzbDrone.Core.Messaging.Commands.CommandPriority,NzbDrone.Core.Messaging.Commands.CommandTrigger) <IL 0x00152, 0x00579>
at (wrapper delegate-invoke) System.Func`6<System.Runtime.CompilerServices.CallSite, NzbDrone.Core.Messaging.Commands.CommandQueueManager, object, NzbDrone.Core.Messaging.Commands.CommandPriority, NzbDrone.Core.Messaging.Commands.CommandTrigger, object>.invoke_TResult__this___T1_T2_T3_T4_T5 (System.Runtime.CompilerServices.CallSite,NzbDrone.Core.Messaging.Commands.CommandQueueManager,object,NzbDrone.Core.Messaging.Commands.CommandPriority,NzbDrone.Core.Messaging.Commands.CommandTrigger) <IL 0x00063, 0x00096>
at NzbDrone.Core.Messaging.Commands.CommandQueueManager.Push (string,System.Nullable`1<System.DateTime>,NzbDrone.Core.Messaging.Commands.CommandPriority,NzbDrone.Core.Messaging.Commands.CommandTrigger) [0x000bb] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Commands\CommandQueueManager.cs:95
at NzbDrone.Core.Jobs.Scheduler.ExecuteCommands () [0x00043] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Jobs\Scheduler.cs:43
at System.Threading.Tasks.TaskActionInvoker/ActionInvoke.Invoke (System.Threading.Tasks.Task,object,System.Threading.Tasks.Task) <IL 0x00006, 0x0001a>
at System.Threading.Tasks.Task.InnerInvoke () <IL 0x0003f, 0x0006c>
at System.Threading.Tasks.Task.ThreadStart () <IL 0x00098, 0x0028f>
[Error] EventAggregator: QualityDefinitionService failed while processing [ApplicationStartedEvent]
database is locked
  at Marr.Data.QGen.UpdateQueryBuilder`1[NzbDrone.Core.Qualities.QualityDefinition].Execute () [0x0003b] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\QGen\UpdateQueryBuilder.cs:157
  at Marr.Data.DataMapper.Update[QualityDefinition] (NzbDrone.Core.Qualities.QualityDefinition entity, System.Linq.Expressions.Expression`1 filter) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\DataMapper.cs:674
  at NzbDrone.Core.Datastore.BasicRepository`1[NzbDrone.Core.Qualities.QualityDefinition].UpdateMany (IList`1 models) [0x00060] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\BasicRepository.cs:173
  at NzbDrone.Core.Qualities.QualityDefinitionService.InsertMissingDefinitions () [0x000d2] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Qualities\QualityDefinitionService.cs:84
  at NzbDrone.Core.Qualities.QualityDefinitionService.Handle (NzbDrone.Core.Lifecycle.ApplicationStartedEvent message) [0x00010] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Qualities\QualityDefinitionService.cs:101
[Info] SceneMappingService: Updating Scene mappings
[Fatal] ConsoleApp: Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
Press any key to exit...
[Info] HousekeepingService: Running housecleaning tasks
database is locked
[Error] HousekeepingService: Error running housekeeping task: CleanupAdditionalNamingSpecs
database is locked
  at NzbDrone.Core.Housekeeping.Housekeepers.CleanupAdditionalNamingSpecs.Clean () [0x0000c] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Housekeeping\Housekeepers\CleanupAdditionalNamingSpecs.cs:18
  at NzbDrone.Core.Housekeeping.HousekeepingService.Clean () [0x00040] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Housekeeping\HousekeepingService.cs:34
[Error] SceneMappingService: Failed to Update Scene Mappings:
database is locked
  at Marr.Data.DataMapper.Delete[SceneMapping] (System.String tableName, System.Linq.Expressions.Expression`1 filter) [0x00091] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\DataMapper.cs:803
  at Marr.Data.DataMapper.Delete[SceneMapping] (System.Linq.Expressions.Expression`1 filter) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\DataMapper.cs:777
  at NzbDrone.Core.Datastore.BasicRepository`1[NzbDrone.Core.DataAugmentation.Scene.SceneMapping].Delete (System.Linq.Expressions.Expression`1 filter) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\BasicRepository.cs:61
  at NzbDrone.Core.DataAugmentation.Scene.SceneMappingRepository.Clear (System.String type) [0x0000d] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\DataAugmentation\Scene\SceneMappingRepository.cs:28
  at NzbDrone.Core.DataAugmentation.Scene.SceneMappingService.UpdateMappings () [0x0003f] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\DataAugmentation\Scene\SceneMappingService.cs:113
I cannot kill the Mono Process even after a restart I was wondering if anyone else has recovered from this issue?
I have tried to reinstall Mono and nzbdrone to no avail I was going to rename the DB and restart the service but I dont want to create any undue work. any help would be appreciated
Which version of mono?
Does the user running Sonarr have write access to /home/jonesd/.config/NzbDrone/nzbdrone.db?
If you rename the DB and restart it will be recreated, does Sonarr function properly then?
Renamed DB Now have the Following
System.Data.SQLite.SQLiteException: disk I/O error
disk I/O error
  at System.Data.SQLite.SQLite3.Prepare (System.Data.SQLite.SQLiteConnection cnn, System.String strSql, System.Data.SQLite.SQLiteStatement previous, UInt32 timeoutMS, System.String& strRemain) [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteCommand.BuildNextCommand () [0x00000] in <filename unknown>:0
Mono version is as follows
Mono JIT compiler version 3.10.0 (tarball Wed Nov 5 12:50:04 UTC 2014)
Permissions should not be an issue as I had never had this problem before yesterday and have not really done anything to affect it.
Run sudo mono --debug NzbDrone.exe
This starts up with the Default Port and works normally I dont think it utilises the same DB as it comes up fresh despite renaming the DB back any other thoughts?
This is the beginning of the root cause
15-8-20 19:28:43.4|Warn|DiskScanService|Unable to apply permissions to: /home/jonesd/media/television/Impractical Jokers
NzbDrone.Mono.LinuxPermissionsException: Error setting file permissions: EPERM
  at NzbDrone.Mono.DiskProvider.SetPermissions (System.String path, System.String mask, System.String user, System.String group) [0x00107] in m:\BuildAgent\work\6c3239faf2b92
630\src\NzbDrone.Mono\DiskProvider.cs:117
  at NzbDrone.Core.MediaFiles.DiskScanService.SetPermissions (System.String path) [0x0001a] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\DiskScanServic
e.cs:152
15-8-20 19:28:43.4|Info|SeriesScannedHandler|[Impractical Jokers] was recently added, performing post-add actions
Ok I’ve resolved this issue
Admin please sticky or do as you will
In case anyone else requires the info the key was the initial error seen in the .config/nzbdrone/log/nzbdrone.log
The issue was corruption to this folder I removed offending material rebooted the server and there you have it. FIXED
