Sonarr will not start on MAC
OS:
((Debug logs)):
Description of issue: I can not get it to open it does nothing when I click it. I goto localhost and just get a screen that says sonarr, nothing ever loads.
Here is the only log i figured out how to pull
https://pastebin.com/0ihJHXm6
It looks like the database is corrupt, ((restoring)) nzbdrone.db from backup should get you up and running again.
Did that and nothing :frowning: I deleted the app, took from a backup 2 weeks ago replaced the config and .db and redownloaded and ran again and got the same issue. On mac is there a easy way to uninstall it all and reinstall? Hoping to not lose all my series settings etc. I have not manually updated mono or sonarr since i installed in 2015. Thanks for the help
What do the logs show now?
Make sure the other nzbdrone.db files nzbdrone.db-shm, nzbdrone.db-wal, etc are also deleted as they will affect the restored database.
Which version of mono is installed? Probably time to update, same with Sonarr, though that won’t fix a problem with the DB.
I will try to remove all the DB. Mono I have no idea where to even check that. its been so long I don’t remember how I even installed it
New photo by Donnie Good
That is all it does.
Hey just wanted to thank you. turns out I wasn’t killing the process. All fixed now!
