Sonarr - Will Not Open
I have been using Sonarr for several months now and think it is great but as of yesterday I cannot access it and only get message saying the webpage is not availble.
In the end I uninstalled the whole thing and made sure I deleted the Nzbdrone folder from the ProgramData file and then reinstalled. However the same issue comes up but this time a box saying:
Epic Fail
TinyloCResolutionException: Unable to resolve type: NzbDrone.Core.Messaging.Events.IHandle’1{{NzbDrone.Core.Lifecycle.ApplicationStartedEvent, NzbDrone.Core, Version=2.0.0.3732, Culture=neutral, PublicKeyToken=null]]
I did not really see anything in the logs apart from right at the end when it showed the following:
16-3-2 13:45:26.9|Info|Router|Application mode: UninstallService
16-3-2 13:45:26.9|Debug|Router|Uninstall Service selected
16-3-2 13:45:26.9|Debug|ServiceProvider|Checking if service NzbDrone exists.
16-3-2 13:45:26.9|Info|ServiceProvider|Uninstalling NzbDrone service
16-3-2 13:45:26.9|Info|ServiceProvider|Stopping NzbDrone Service…
16-3-2 13:45:26.9|Info|ServiceProvider|Service is currently Stopped
16-3-2 13:45:26.9|Warn|ServiceProvider|Service NzbDrone is already in stopped state.
16-3-2 13:45:31.9|Info|ServiceProvider|NzbDrone successfully uninstalled
Any ideas as to how I can resolve this??
Did you uninstall Sonarr? That wouldn’t happen automatically. Probably the quickest thing would be to reinstall Soanrr using the latest installed from https://sonarr.tv
Hi Markus101,
I just removed again and reinstalled and get the same issue with the “webpage is not available” although the end of the log now has the following:
16-3-2 19:51:41.4|Info|Router|Application mode: Service
16-3-2 19:51:41.4|Debug|Router|Service selected
16-3-2 19:51:41.8|Info|OwinHostController|Listening on the following URLs:
16-3-2 19:51:41.8|Info|OwinHostController| http://*:8989/
16-3-2 19:51:43.0|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
16-3-2 19:51:43.0|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
16-3-2 19:51:43.0|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
16-3-2 19:51:43.1|Info|NancyBootstrapper|Starting NzbDrone API
16-3-2 19:51:43.2|Trace|EventAggregator|Publishing ApplicationStartedEvent
16-3-2 19:51:53.8|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.3732
16-3-2 19:51:54.1|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone.Console
16-3-2 19:51:54.1|Debug|ProcessProvider| - [3728] NzbDrone.Console
16-3-2 19:51:54.1|Warn|ProcessProvider|Couldn’t get process info for NzbDrone.Console
System.ComponentModel.Win32Exception (0x80004005): Access is denied
at System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
at System.Diagnostics.NtProcessManager.GetFirstModuleInfo(Int32 processId)
at System.Diagnostics.Process.get_MainModule()
at NzbDrone.Common.Processes.ProcessProvider.GetExeFileName(Process process) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Processes\ProcessProvider.cs:line 304
at NzbDrone.Common.Processes.ProcessProvider.ConvertToProcessInfo(Process process) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Processes\ProcessProvider.cs:line 285
16-3-2 19:51:54.2|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone
16-3-2 19:51:54.2|Debug|ProcessProvider| - [9384] NzbDrone
16-3-2 19:51:54.2|Info|SingleInstancePolicy|1 instance(s) of Sonarr are running
16-3-2 19:51:54.2|Warn|SingleInstancePolicy|Another instance of Sonarr is already running.
16-3-2 19:51:54.2|Info|BrowserService|Starting default browser. http://localhost:8989
16-3-2 19:51:54.2|Info|ProcessProvider|Opening URL [http://localhost:8989]
16-3-2 19:51:54.9|Info|Bootstrap|Application is being terminated. Reason : Another instance is already running
I don’t have another instance running and deleted all the files prior to me downloading it again.
Double check that the nzbdrone service is not running and that it isn’t listed in Task Manager. If all else fails, reboot.
