I have a RapidSSL cert installed on my Windows 10 machine, I know it works correctly as I am using it on SABnzbd and a couple other things. The problem is I can’t get Sonarr to open into HTTPS no matter what I do. I have checked the config and everything is good there. I have used netsh to delete the reserved urls. I have attached the logs…it looks like it connects to the SSL just fine but its going with the HTTP option first even with SSL enabled. Any ideas? I will attach my settings/config file too…
**I replaced some of the digits in my ssl hash with *…there are no phantoms in it and it matches up
Sonarr Logs: http://pastebin.com/EK45u1d4
Sonarr Config: http://pastebin.com/EqLv8kdV
I am running Sonarr Ver. 2.0.0.3953 on a Windows 10 Home machine with a paid SSL from RapidSSL that works with SABnzbd with no issues at all.
