Sonarr version (exact version): Version 2.0.0.5228
Mono version (if Sonarr is not running on Windows):Version 2.0.0.5228
OS: Ubuntu 16.04.5 LTS
[Info] RefreshEpisodeService: Starting episode info refresh for: [282670][Narcos]
[Info] RefreshEpisodeService: Finished episode refresh for series: [282670][Narcos].
[Info] DiskScanService: Scanning disk for Narcos
[Info] DiskScanService: Completed scanning disk for Narcos
[Info] ExistingMetadataImporter: Found 0 existing metadata files
[Info] ExistingSubtitleImporter: Found 0 existing subtitle files
*** Error in `mono’: double free or corruption (!prev): 0x00007f5ed09007a0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f5ef03117e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7f5ef031a37a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f5ef031e53c]
/usr/lib/x86_64-linux-gnu/libmediainfo.so.0(+0xc721f)[0x7f5ee48e921f]
/usr/lib/x86_64-linux-gnu/libmediainfo.so.0(MediaInfo_Open_Buffer_Finalize+0x8f)[0x7f5ee4c7f9ff]
[0x41a1684d]
[This is my first ever post with an issue - be gentle ;)]
So - have been running Sonarr since 2015 with almost no problems (or nothing I couldn’t solve with some sensible Googling).
My logs show that the last time Sonarr successfully started up on my HP Gen8/Ubuntu 16.04.5 build was 5 days ago. I may have ran a apt-get update/upgrade around then (I cannot honestly be certain), but certainly no other changes. Having rebooted server several times, Sonarr clearly isn’t starting any more.
I ran a mono debug, which ended with the following error:
Debug info from gdb:
Could not attach to process. If your uid matches the uid of the target
process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
/tmp/mono-gdb-commands.dpbNw9:1: Error in sourced command file:
ptrace: Operation not permitted.
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted (core dumped)
Looking back up through the same debug, I can see the point at which it failed (I think) and have included it above.
The full mono debug log can be found here: https://www.dropbox.com/s/o16yqqe97bk8k66/Sonarr_debug?dl=0
Any suggestions from the community on next steps to fix this gratefully received.
Thanks.
