Sonarr Web UI Series Categories
Pretty straight forward what I’d like to request, simply a way to add customizable categories for the shows sonarr is monitoring (for the web UI only) .
I believe this would be a valuable feature for people monitoring a lot of shows and wants to manually sort them into different groups i.e. “Horror”, “Drama” or “Kids Shows”, “Jim’s Shows”, “Parents Shows”.
You could also use the feature to split up the listing based on if they’ve ended (and you don’t want to remove monitoring in hopes of future reboots - i.e. X-Files) by having a category named as such and moving them into it.
A picture is worth a thousand words so I’ve quickly whipped one up where someones has two catagories one being “Jeff’s Shows” and the other “Ended Shows” - excuse its crudeness.
I don’t see grouping being done, but filtering based on Tags is something we’re considering.
