Sonarr Web Interface not loading - Ubuntu 16.04
Sonarr version (exact version): Version 2.0.0.4146
Mono version (if Sonarr is not running on Windows): version 4.4.0
OS: Ubuntu 16.04 LTS
((Debug logs)) (posted to hastebin or similar): http://hastebin.com/javozimoqo.1c
Description of issue: Sonarr interface won’t load. It’s processing files, I can see them being downloaded but when I load the interface, it just hangs on the loading animation.
I saw the advice that was provided here: Sonarr Web Interface not loading
But I don’t know to restore from backup and definitely don’t know how to use SQLite.
Any advice?
That advice was specific to that issue, your logs don’t show any issues (just a series refresh), if you restart Sonarr does the interface load? Can you post log files after attempting to load the UI?
I tried restarting Sonarr and the server several times, didn’t work.
Then I tried the SQLite3 (UPDATE Series SET Actors = ‘[]’) solution you gave in the other thread and it solved the problem. It was easier to do than I thought it would be.
Thanks!
