Sonarr version (exact version): 3.0.3.620
Mono version (if Sonarr is not running on Windows):5.20.1.34
OS:
Debug logs: https://pastebin.com/UTKDnM5L
Description of issue: When I try to load the web gui I get an error saying failed to load (usully series) from API.
Sonarr is behind an nginx proxy and if I bypass it by using ngrok it seems to load just fine. There are no errors in the nginx logs but a couple in the sonarr logs.
There are also a few errors in chrome’s developers console. I can provide those if needed.
Any help would be greatly appreciated!
