Can you please add at least MD5 Hashing capability to storing torrent, client, etc. information connections? While this is a great utility, easily being able to query those from SQLite3 database is concerning.
It’s an issue, but if someone has access to the disk on your computer you’ll have bigger problems.
If Sonarr stored everything as MD5 then it’d be unable to use it, MD5 is hashing, not encryption.
If Sonarr encrypted things then the keys to that encryption would need to need to be stored so Sonarr could decrypt things, so you’re either going to have to type a password every time Sonarr starts or store the keys to the kingdom right along side the DB, buying you very little time.
