Installed Sonarr on Synology DS411j but cant access the GUI URL (just get connection refused or cant reach page dependant on browser used).
I’m using http://IP:8989 and have no firewalls etc set.
Sonarr Version is 20150731-8
Mono 4.2.2.30-7
Mono 4.2.2.30-7
Based on the logs there doesn’t appear to an issue with the web server and it is successfully listening on port 8989.
I do see errors with Sonarr timing out connecting to external services, it could be related, but may be something else.
Unless you upgraded the RAM that’s very likely the issue, 128MB in the default configuration is not enough for Sonarr to run happily alongside anything else that is running.
