I’m running into an issue where after I do the initial configuration in Sonarr and reboot I can no longer get to the web interface. I can see the processes in task manager but I pull up the Sonarr page and it just says it’s not available. I’ve tried ending the task, restarting the service and running sonarr again to no avail. I’ve even removed sonarr and re-installed it.
Here’s some logs - I can see it getting some access denied error.
http://pastebin.com/qp7rJT7K
Windows 8.1
I should also mention that I’m using chrome and the latest version of sonarr. I’ve made sure the firewall was allowing the connection as well.
I suspect the issue may be with the port, anything below 1024 should not be used.
Logs are full of messages saying its already running, try changing the port back to 8989 and see if that works. You can change the port directly in config.xml in C:\ProgramData\NzbDrone
Yeah I just figured it out while talking in the IRC. I posted a couple links in there. The weird part is I never changed the default port on either installation (I re-installed it twice.)
Auto complete might have, probably something saved from when you setup SAB or get.
