Sonarr version (exact version) : 2.0.0.5344
Mono version (if Sonarr is not running on Windows) : 5.20.1.34
OS : Ubuntu 18.04.4 LTS
AppData directory /config
Startup directory /opt/NzbDrone
Debug logs : https://ufile.io/vjlwuncs
Description of issue :
Running Docker-Compose
sonarr:
container_name: sonarr
restart: unless-stopped
ports:
- 8989:8989
volumes:
- /home/server/docker/sonarr:/config
- /home/server/downloads:/downloads
- /mnt/SeagateExternal/Series/:/tv
- /mnt/Backup/Series/:/Series2/
environment:
- PUID=501
- PGID=1000
- TZ=Europe/Athens
- UMASK_SET=022
image: linuxserver/sonarr
depends_on:
- nzbget
- transmission
- jackett
links:
- nzbget:nzbget
- transmission:transmission
And file download works fine, the file is downloaded to
/downloads/completed/Series
But Sonarr fails to move it as it looks in
20-3-17 01:15:27.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: /data/completed/Series/Last Week Tonight with John Oliver (2014) S07E04 March 8 (1080p AMZN Webrip x265 10bit EAC3 2.0 - ArcX).mkv
So it looks inside /data/ instead of /downloads/
Where do I configure that?
Edit: Also not sure why its trying
20-3-16 22:23:17.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: /downloads/completed/Series/Last.Week.Tonight.with.John.Oliver.S07E05.1080p.WEB.H264-XLF
Sonarr have not added that file to either transmission nor nzbget, so not sure why it expects to find that file in that folder
