Sonarr + Transmission Mac not removing downloads even after seeding
Once a download has finished seeding, Sonarr is supposed to clean up after itself and tell Transmission to delete the downloaded files.
Shows are imported as normal and everything is otherwise working as expected.
Do you have Remove Completed Downloads enabled? (It’s disabled by default)
Yes, enable and remove are both on.
Remove from Transfer List when Seeding completes would mean Sonarr wouldn’t know it’s complete, it would just disappear, you’ll want to disable that.
That did it, thanks!
