Sonarr to remote Deluge Client
3.0.8.1507
Windows
Windows 11
NA on logs
Error/help needed:
Adding a download client on a remote host
Remote host Deluge works fine
Daemon running
Remote host is Ubuntu 20.03
Deluge version 2.0.3
Thin Client mode
Local Deluge GTK can connect with Local Client/8112
Windows machine settings
Enable Checked
Host (remote machine IP)
Port 58846
Use SSL = Checked
URL Base - Blank
Password - User password (validated)
Rest is defaults
Error:
Unknown exception: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.**:
Summary: On the remote machine, Sonarr install locally, can connect with no issue to local install Deluge. Attempting to connect and run Deluge from a Remote windows 11 machine with the above setting can not connect with the above error.
You cannot use SSL without a valid SSL Cert… and you can’t particularly get those for an IP address
Disable SSL or fix your remote so it’s using a domain and valid ssl cert
Thank you for the quick response: The remote machine had it checked (the one with Deluge and Sonarr installed. Makes sense that local would not need that, but remote may.
I removed the check box for SSL and get the error message Verify SSL settings
I am just fighting the hand shake between the two software applications and neither have very good documentation or examples. Do I need the SSL to do a remote connection from a local host to a hosted environment in the cloud?
Any other suggestions or links to documents I may be over looking?
