Have a problem with Sonarr getting stuck on refreshing certain shows and seems to be getting stuck and then just starting the whole process again and over again. I’ve searched all similar posts but none of the fixes have worked,
I’m running vers 2.00.3357 mono:4.0.2 on unraid server in a docker.
I’ve had to remove all the shows as slowing down sonarr by repeating the loop.
Which OS?
Whoxh version of mediainfo?
I’m Using Unraid 6.0.6
I’m unsure where to check mediainfo version
You’ll need to out which version libmediainfo.so.0
points to.
Is there a specific log or settings page i should be looking at for this as checked several times and still can’t find it
Its not part of Sonarr, but its something Sonarr relies on to operate.
I believe you may be seeing this issue: https://github.com/Sonarr/Sonarr/issues/742
I managed to fix this by installing a different docker for sonarr but never did find where mediainfo files where
