Hi,
I am having a problem where Sonarr web GUI won’t actually load… I am using Unraid 6.3.3 and Sonarr worked perfectly until recently, possibly since i did an update… The problem is that when i select WebGUI it just gets stuck at the loading screen with 4 dots moving left and right across the screen and the words Sonarr Ver. at the bottom.
Unfortunately as i cant load the actual software i cant tell you the exact version, but i can still access the Unraid Log, where it says this;
Error] DownloadDecisionMaker: Couldn’t process release.
[v2.0.0.4753] System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database
Can anyone help me with pointing me in the right direction with this?
Many thanks
