Mono version (if Sonarr is not running on Windows): 5.18.0.240 (edit: updated to 5.18.0.268)
OS: Linux Mint
Debug logs: https://pastebin.com/yuEiufmK
Trace logs of one boot cycle. I can attach debug logs if trace logs are too wordy.
Shortly after booting the machine, sonarr will stop responding. The machine will also hang on a reboot while trying to stop sonarr. Of note: my library is on a NAS and completed downloads are copied to the network drive mounted as “/srv/osmc/” (this mount point is a legacy of a previous configuration). If I turn off the NAS, sonarr will not hang so the issue is with file handling.
This is still an issue. It disappeared for a week or so and now it’s happening again. Sonarr just stops responding, nothing in the logs, systemctl says its active.
