All of a sudden last night my Sonaar decide to stop working.
I have it installed as a service in Windows but the service status is blank when I start it manually I get the following pop up error:
“The NzbDrone service on Local Computer started and then stopped some services stop automatically if they are not in use by other services or programs”
Here is my sonar log file from when I start the Windows Service…
http://pastebin.com/eYeBKGSH
It appears that my couchpotato is not responding as well I’m stumped at the moment any help would be appreciated.
Since my configuration hadn’t changed in a while I was able to grab the config.xml from a backup and restore sonar. I’m now able to start the Windows Service and login to the Console.
I would still like to know what happened since my Couch is having the same problem.
Thats the full log from Sonarr on startup? There isn’t any mention of Sonarr’s web server starting it just appears to stop. If the config file was corrupt that would be logged.
Correct. I started the Windows Service and that was what was captured.
Here is the log when it actually occurred the first time you can see the entry around 16:31
http://pastebin.com/Y0TpfMRi
