Hi,
I’m realtively new to Sonarr so apologies if I’ve missed something simple here. After setting it all up a few weeks ago everything worked fine. Then all of a sudden Sonarr stopped working, I can’t even start it.
I checked my event viewer and can see the following errors when you try to open the application.
Application: NzbDrone.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at NzbDrone.WindowsApp.Main(System.String)
Faulting application name: NzbDrone.exe, version: 2.0.0.4617, time stamp: 0x58ae98f2
Faulting module name: KERNELBASE.dll, version: 10.0.14393.479, time stamp: 0x58256d37
Exception code: 0xe0434352
Fault offset: 0x000da832
Faulting process ID: 0x17a0
Faulting application start time: 0x01d2902c44a25632
Faulting application path: C:\ProgramData\NzbDrone\bin\NzbDrone.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report ID: 53c99b13-0ed5-4bff-89fd-b490f16c92f1
Faulting package full name:
Faulting package-relative application ID:
Fault bucket 108760241115, type 1
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: NzbDrone.exe
P2: 2.0.0.4617
P3: 58ae98f2
P4: KERNELBASE.dll
P5: 10.0.14393.479
P6: 58256d37
P7: e0434352
P8: 000da832
P9:
P10:
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER96C7.tmp.WERInternalMetadata.xml
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_NzbDrone.exe_72224ed5cec494b3e9be811ca9c12c35145a3f4_cc921a9e_25079ace
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
Hashed bucket: e3a43cccb7de675945412869135c366b
I then downloaded the latest version of Sonarr and after installtion all worked again. Next day, turned my PC on and am back to the above errors.
Does anyone know what file it is likely missing or how I can resolve this?
Thanks.
