Sonarr version (exact version): 2.0.0.4472 Mono version (if Sonarr is not running on Windows): OS: win 10 ((Debug logs)): (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue: New set up so excuse all questions, I set up and new episodes of TV shows that aired downloaded last night as expected. However they now show in sonarr as incomplete ?
IT also doesnt seem to use the correct file path for the show, its downloading to the default folder location SAZNZB uses?
What seems to happen is sonarr grabs the episode and it shows as downloading and 100% oin the activitiy screen,the calendar shows it as downloading, but never seems to go green as downloaded. Then a little later shows as missing.
History shows it downloaded (plus the files are still on the disk)
Im assuming that this is linked to the fact its not putting the shows into the correct folder path and thus a later scan cant then find them?
Using a NAS but running Sonar as a user account rather than system if that makes any difference.
Using a NAS it wont allow use of drive letters. Sonarr set up with UNC but SAZNZB was using drive letters as its default download location on the NAS. Changed to UNC and it seems happier.
