Sonarr sending "metafiles" to rtorrent - metafile not downloading
I seem to be having some problems with getting sonnar to work with kickass torrents. I have managed to get sonnar connect to rtorrent - rutorrent, and sonarr seems to be taking a file and loading it into rtorrent-rutorrent but when it is loaded and i look at my rutorrent webpage to see progress of downloaded file it is not downloading .
The file is a metafile, looks something similar to “45287245412248812448.meta” and it will not download.
has anyone else had this happen and any suggestions on how to fix it?
I am using kickass-torrents as the torrent provide.
When downloading a torrent file directly from kickass, (not using sonarr) it works perfectly , it seems to be something n the way sonnar handles the files and puts them into rtorrent -rutorrent.
any ideas, anyone ?
meta is a magnet link, needs DHT to be enabled.
Hi, thank you for taking the time to help . working perfectly now… thanks again
