Sonarr version: 2.0.0.5054
Mono version: 4.8.1
OS: FreeNAS-11.0-U4 (FreeBSD)
Whenever i try to add a tv show and get to the point where i have to select the Path, the following error pops up:
This is how i setup my datasets (every jail has a seperate dataset under the “apps” dataset for config files):
These are my jails:
And these are the mounts:
I changed the permissions of the /mnt/tank/media dataset (with “set permission recursively” enabled) to the default FreeNAS media user/group with UID&PGID “8675309” (also not sure if i should use this default media user and group or create a new one myself?):
This is the output i get when performing the cmd ls - l
inside the sonarr jail:
I do have a user & group sonarr:sonarr which has access to the config files, but im not sure which command i should use to enable sonarr access to the media dataset. I have seen some posts about adding media:media to sonarr, but im unsure how to do this?
