Sonarr On Synology Won't Start
20150731-8:
4.2.2.30-7:
synology:
Mar 29 21:29:53 DiskStation synoscgi_SYNO.Core.Package.Control_1_start[30160]: service_stop.c:23 synoservice: [pkgctl-nzbdrone] stopping …
Mar 29 21:29:54 DiskStation synoscgi_SYNO.Core.Package.Control_1_start[30160]: service_stop.c:86 synoservice: [pkgctl-nzbdrone] stopped.
Mar 29 21:29:54 DiskStation synoscgi_SYNO.Core.Package.Control_1_start[30160]: service_start.c:74 synoservice: [pkgctl-nzbdrone] starting …
Mar 29 21:29:56 DiskStation synoscgi_SYNO.Core.Package.Control_1_start[30160]: service_start.c:178 synoservice: [pkgctl-nzbdrone] started.
**Not sure if an update came through and broke it but I dont think so. The service just stopped this weekend and won’t start. I’ve tried to uninstall and reinstall both Sonarr and Mono and i still get the same result. It tries to start and then the GUI says stopped. The log above shows that it starts but the service is not actually running. **:
also there doesnt seem to be any log files /usr/local/nzbdrone/var/.config/NzbDrone
Did you install DSM 6?
https://forums.sonarr.tv/search?q=dsm%206
Those aren’t Sonarr logs, we’d need to see them to see if Sonarr is even being started.
yep looks like it updated to dsm6, sorry i didnt see that earlier.
That is what i thought was odd, there are no sonarr logs. Is there anyway i can export the config w/o it being started so i can set it up on a windows machine until it works with dsm?
Yeah, you’ll need to find it, but just follow the manual steps to ((backup)) .
((Log files)) Might have some info on where it is located as well.
So unfortunately my Synology automatic updated to DSM 6.0 I can not open Sonarr. When will there be an update? Is there a workaround?
Ty.
https://www.reddit.com/r/sonarr/comments/4c7ddp/howto_sonarr_on_synology_dsm_60_workaround/
Thank you, will try this!
