Sonarr on Synology with Mono 3.10 won't stay running
Yesterday I upgraded Mono on my Synology to 3.10 and this broke Sonarr. I was using the dev branch. If you start Sonarr it stays running for only about 1-2 seconds, then stops. I tried uninstalling Sonarr und reinstalled it but without any luck.
Does anyone know what could be causing this?
Edit: Looking at the log it looks like an issue with the DB after reinstallation:
15-1-1 13:38:33.0|Info|Bootstrap|Starting NzbDrone - /volume1/@appstore/nzbdrone/share/NzbDrone/NzbDrone.exe - Version 2.0.0.2556
15-1-1 13:38:34.2|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
15-1-1 13:38:34.3|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone
15-1-1 13:38:34.8|Info|MigrationLogger|*** Migrating data source=/usr/local/nzbdrone/var/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True ***
15-1-1 13:38:34.8|Fatal|ConsoleApp|EPIC FAIL!
System.TypeInitializationException: An exception was thrown by the type initializer for System.Data.SQLite.SQLiteFactory ---> System.DllNotFoundException: libsqlite3.so.0
  at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods:sqlite3_config_none (System.Data.SQLite.SQLiteConfigOpsEnum)
  at System.Data.SQLite.SQLite3.StaticIsInitialized () [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteLog.Initialize () [0x00000] in <filename unknown>:0
  at System.Data.SQLite.SQLiteFactory..cctor () [0x00000] in <filename unknown>:0
  at NzbDrone.Core.Datastore.Migration.Framework.MigrationDbFactory.CreateFactory () [0x00000] in <filename unknown>:0
  at FluentMigrator.Runner.Processors.DbFactoryBase.get_Factory () [0x00000] in <filename unknown>:0
  at FluentMigrator.Runner.Processors.DbFactoryBase.CreateConnection (System.String connectionString) [0x00000] in <filename unknown>:0
  at NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSqliteProcessorFactory.Create (System.String connectionString, IAnnouncer announcer, IMigrationProcessorOptions options) [0x00000] in <filename unknown>:0
  at NzbDrone.Core.Datastore.Migration.Framework.MigrationController.MigrateToLatest (System.String connectionString, MigrationType migrationType) [0x00000] in <filename unknown>:0
  at NzbDrone.Core.Datastore.DbFactory.Create (MigrationType migrationType) [0x00000] in <filename unknown>:0
  at NzbDrone.Core.Datastore.DbFactory.RegisterDatabase (IContainer container) [0x00000] in <filename unknown>:0
  at NzbDrone.Host.Bootstrap.Start (ApplicationModes applicationModes, NzbDrone.Common.EnvironmentInfo.StartupContext startupContext) [0x00000] in <filename unknown>:0
  at NzbDrone.Host.Bootstrap.Start (NzbDrone.Common.EnvironmentInfo.StartupContext startupContext, IUserAlert userAlert, System.Action`1 startCallback) [0x00000] in <filename unknown>:0
  at NzbDrone.Console.ConsoleApp.Main (System.String[] args) [0x00000] in <filename unknown>:0
You’ll need to get back onto the develop build since the database is incompatible.
If the UI is loading you can update from System: Update, if its not I would suggest backing up your database, removing the database so it is recreated, starting up, installing the latest develop build via System: Update then restoring the DB. The restore instructions are here to backup you will need to copy nzbdrone.db from that location first (before running the rm command).
The UI is not working. And I tried starting it without a DB which resulted in another error. But luckily a new package version was published today which installed just fine and started without the DB. I changed the branch to develop, stopped Sonarr and restored the DB from backup and then it finally worked.
Glad to hear its working.
Is that a new package in the syno community repo?
It looks like it. It says it is version 20150101-3. So from today I guess.
