Sonarr on Synology DS213+
Hi,
I recently bought a DS213+ (qoriq package arch) and was all excited about installing sonarr on this machine. However, turns out that Sonarr isn’t build for this type of CPU (?). Does anyone know if I can use Sonarr on a Synology DS213+ ?
thanks,
Jeroen
No, mono support on qoriq is either completely broken or broken in a way that it won’t work with Sonarr.
Markus, thanks for your reply. I’ll look for alternatives,
cheers,
Jeroen
It’s completely broken, not specific to Sonarr.
Nono won’t run on it. Not without a developer adjusting the jitter for the qoriq cpu instruction set, which prolly will never happen.
