Sonarr not updating/finding A Discovery of Witches
I added this show, which Sonarr found, a couple of months ago and episodes have begun airing and are present on USENET but Sonarr still doesn’t have the Season 1 episode list nor is it finding the episodes. The series is on tvdb as an English language show.
It sounds like you have an incorrect version of that show added, likely a dupe that was removed by TheTVDB at some point.
You should remove the series and re-add it, as I’m seeing an episode list for that series.
Thank You Sir! That did the trick.
