Sonarr version (3.0.8.1507):
Mono version (6.12.0.182):
Ubuntu 20.04:
I have just done a fresh install and I get get Sonarr to start I have no idea whats up when i run sudo systemctl status sonarr.service I get this but to be honest doesnt really know what it means.
sonarr.service - Sonarr Daemon
Loaded: loaded (/lib/systemd/system/sonarr.service; disabled; vendor preset: enabled)
Active: active (running) since Thu 2022-07-14 12:55:21 BST; 2s ago
Main PID: 86780 (mono)
Tasks: 6 (limit: 9255)
Memory: 42.4M
CGroup: /system.slice/sonarr.service
└─86780 /usr/bin/mono --debug /usr/lib/sonarr/bin/Sonarr.exe -nobrowser -data=/var/lib/sonarr
Jul 14 12:55:21 plexserver systemd[1]: Started Sonarr Daemon.
Jul 14 12:55:22 plexserver mono[86780]: [Info] Bootstrap: Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.8.1507
Jul 14 12:55:22 plexserver mono[86780]: [Info] AppFolderInfo: Data directory is being overridden to [/var/lib/sonarr]
Jul 14 12:55:23 plexserver mono[86780]: [Info] Router: Application mode: Interactive
Jul 14 12:55:23 plexserver mono[86780]: [Info] MigrationLogger: *** Checking database for required migrations data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
Jul 14 12:55:23 plexserver mono[86780]: [Info] MigrationLogger: *** Checking database for required migrations data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
Just found the log file
2022-07-14 13:10:33.3|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
2022-07-14 13:10:33.3|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
2022-07-14 13:10:33.8|Info|SonarrBootstrapper|Starting Web Server
2022-07-14 13:10:34.9|Fatal|ConsoleApp|Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
2022-07-14 13:10:38.3|Debug|ProcessProvider|Found 0 processes with the name: Sonarr.Console
2022-07-14 13:10:38.7|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2022-07-14 13:10:38.7|Debug|ProcessProvider| - [90021] Sonarr
2022-07-14 13:10:38.7|Info|Router|Application mode: Interactive
2022-07-14 13:10:38.7|Debug|Router|Console selected
2022-07-14 13:10:38.9|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2022-07-14 13:10:39.2|Debug|MigrationLogger|Took: 00:00:00.2312281
2022-07-14 13:10:39.2|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2022-07-14 13:10:39.2|Debug|MigrationLogger|Took: 00:00:00.0278075
2022-07-14 13:10:39.5|Debug|InstallUpdateService|Post-install update check requested
2022-07-14 13:10:39.5|Debug|InstallUpdateService|Built-in updater disabled, skipping post-install update check
2022-07-14 13:10:39.5|Info|OwinHostController|Listening on the following URLs:
2022-07-14 13:10:39.5|Info|OwinHostController| http://*:7878/
2022-07-14 13:10:39.5|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
2022-07-14 13:10:39.6|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
2022-07-14 13:10:39.6|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
2022-07-14 13:10:40.1|Info|SonarrBootstrapper|Starting Web Server
2022-07-14 13:10:41.2|Fatal|ConsoleApp|Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
2022-07-14 13:10:44.3|Debug|ProcessProvider|Found 0 processes with the name: Sonarr.Console
2022-07-14 13:10:44.7|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2022-07-14 13:10:44.7|Debug|ProcessProvider| - [90039] Sonarr
2022-07-14 13:10:44.7|Info|Router|Application mode: Interactive
2022-07-14 13:10:44.7|Debug|Router|Console selected
2022-07-14 13:10:44.9|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2022-07-14 13:10:45.2|Debug|MigrationLogger|Took: 00:00:00.2308537
2022-07-14 13:10:45.2|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2022-07-14 13:10:45.2|Debug|MigrationLogger|Took: 00:00:00.0281574
2022-07-14 13:10:45.5|Debug|InstallUpdateService|Post-install update check requested
2022-07-14 13:10:45.5|Debug|InstallUpdateService|Built-in updater disabled, skipping post-install update check
2022-07-14 13:10:45.5|Info|OwinHostController|Listening on the following URLs:
2022-07-14 13:10:45.5|Info|OwinHostController| http://*:7878/
2022-07-14 13:10:45.6|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
2022-07-14 13:10:45.6|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
2022-07-14 13:10:45.6|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
2022-07-14 13:10:46.1|Info|SonarrBootstrapper|Starting Web Server
2022-07-14 13:10:47.2|Fatal|ConsoleApp|Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
2022-07-14 13:10:50.3|Debug|ProcessProvider|Found 0 processes with the name: Sonarr.Console
2022-07-14 13:10:50.7|Debug|ProcessProvider|Found 1 processes with the name: Sonarr
2022-07-14 13:10:50.7|Debug|ProcessProvider| - [90057] Sonarr
2022-07-14 13:10:50.7|Info|Router|Application mode: Interactive
2022-07-14 13:10:50.7|Debug|Router|Console selected
2022-07-14 13:10:50.9|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2022-07-14 13:10:51.2|Debug|MigrationLogger|Took: 00:00:00.2314152
2022-07-14 13:10:51.2|Info|MigrationLogger|*** Checking database for required migrations data source=/var/lib/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
2022-07-14 13:10:51.2|Debug|MigrationLogger|Took: 00:00:00.0277582
2022-07-14 13:10:51.5|Debug|InstallUpdateService|Post-install update check requested
2022-07-14 13:10:51.5|Debug|InstallUpdateService|Built-in updater disabled, skipping post-install update check
2022-07-14 13:10:51.5|Info|OwinHostController|Listening on the following URLs:
2022-07-14 13:10:51.5|Info|OwinHostController| http://*:7878/
2022-07-14 13:10:51.5|Debug|OwinAppFactory|Attaching NzbDroneVersionMiddleWare to host
2022-07-14 13:10:51.6|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
2022-07-14 13:10:51.6|Debug|OwinAppFactory|Attaching NancyMiddleWare to host
2022-07-14 13:10:52.1|Info|SonarrBootstrapper|Starting Web Server
2022-07-14 13:10:53.2|Fatal|ConsoleApp|Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
When I check for ports 8989 is not there
sudo lsof -i -P -n | grep LISTEN
systemd-r 719 systemd-resolve 13u IPv4 26171 0t0 TCP 127.0.0.53:53 (LISTEN)
python3 867 root 10u IPv4 42817 0t0 TCP *:8181 (LISTEN)
anydesk 915 root 22u IPv4 37080 0t0 TCP *:7070 (LISTEN)
sshd 927 root 3u IPv4 31510 0t0 TCP *:22 (LISTEN)
sshd 927 root 4u IPv6 31512 0t0 TCP *:22 (LISTEN)
Ombi 1204 ombi 372u IPv6 43655 0t0 TCP *:5000 (LISTEN)
Plex\x20M 1248 plex 56u IPv6 39965 0t0 TCP *:32400 (LISTEN)
Plex\x20M 1248 plex 57u IPv4 39967 0t0 TCP 127.0.0.1:32401 (LISTEN)
Plex\x20S 1459 plex 8u IPv4 40142 0t0 TCP 127.0.0.1:33973 (LISTEN)
node 1494 root 23u IPv6 44458 0t0 TCP *:5055 (LISTEN)
sabnzbdpl 1515 paul 4u IPv4 42006 0t0 TCP *:8080 (LISTEN)
Plex\x20T 1638 plex 10u IPv4 41329 0t0 TCP 127.0.0.1:32600 (LISTEN)
Radarr 6485 paul 215u IPv6 66168 0t0 TCP *:7878 (LISTEN)
cupsd 19702 root 6u IPv6 162995 0t0 TCP [::1]:631 (LISTEN)
cupsd 19702 root 7u IPv4 162996 0t0 TCP 127.0.0.1:631 (LISTEN)
Hope this helps sort the problem
Thankyou Paul
