Sonarr version v2.0.0.4645:
Windows 7:
Hi, my Sonar has just decided to throw its toys out of the pram, and had decided that it no longer wants to function. I’m getting a windows epic fail error message “InvalidProgramException: Common Language Runtime detected an invalid program” when trying to run. I have uninstalled and reinstalled Sonarr, and restored the nzbdrone.db and config.xml from backups.
Sonarr has been running just fine for the past 9 months or so.
Here’s the log:
[v2.0.0.4645] System.InvalidProgramException: Common Language Runtime detected an invalid program.
at System.Data.DataColumn.set_Item(Int32 record, Object value)
at System.Data.DataTable.NewRecordFromArray(Object[] value)
at System.Data.DataTable.LoadDataRow(Object[] values, Boolean fAcceptChanges)
at System.Data.ProviderBase.SchemaMapping.LoadDataRow()
at System.Data.Common.DataAdapter.FillLoadDataRow(SchemaMapping mapping)
at System.Data.Common.DataAdapter.FillFromReader(DataSet dataset, DataTable datatable, String srcTable, DataReaderContainer dataReader, Int32 startRecord, Int32 maxRecords, DataColumn parentChapterColumn, Object parentChapterValue)
at System.Data.Common.DataAdapter.Fill(DataSet dataSet, String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords)
at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet)
at FluentMigrator.Runner.Processors.SQLite.SQLiteProcessor.Read(String template, Object[] args) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\Processors\SQLite\SQLiteProcessor.cs:line 193
at FluentMigrator.Runner.Processors.SQLite.SQLiteProcessor.ColumnExists(String schemaName, String tableName, String columnName) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\Processors\SQLite\SQLiteProcessor.cs:line 52
at FluentMigrator.Runner.VersionLoader.get_AlreadyMadeVersionUnique() in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\VersionLoader.cs:line 132
at FluentMigrator.Runner.VersionLoader.LoadVersionInfo() in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\VersionLoader.cs:line 163
at FluentMigrator.Runner.VersionLoader…ctor(IMigrationRunner runner, IAssemblyCollection assemblies, IMigrationConventions conventions) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\VersionLoader.cs:line 50
at FluentMigrator.Runner.MigrationRunner…ctor(IAssemblyCollection assemblies, IRunnerContext runnerContext, IMigrationProcessor processor) in C:\Users\Mark\Source\Repos\fluentmigrator\src\FluentMigrator.Runner\MigrationRunner.cs:line 102
at NzbDrone.Core.Datastore.Migration.Framework.MigrationController.Migrate(String connectionString, MigrationContext migrationContext) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\Migration\Framework\MigrationController.cs:line 43
at NzbDrone.Core.Datastore.DbFactory.Create(MigrationContext migrationContext) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\DbFactory.cs:line 84
at NzbDrone.Core.Datastore.DbFactory.Create(MigrationType migrationType) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\DbFactory.cs:line 56
at NzbDrone.Core.Datastore.DbFactory.RegisterDatabase(IContainer container) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Datastore\DbFactory.cs:line 36
at NzbDrone.Host.Bootstrap.Start(ApplicationModes applicationModes, StartupContext startupContext) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Host\Bootstrap.cs:line 73
at NzbDrone.Host.Bootstrap.Start(StartupContext startupContext, IUserAlert userAlert, Action`1 startCallback) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Host\Bootstrap.cs:line 40
at NzbDrone.Console.ConsoleApp.Main(String[] args) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Console\ConsoleApp.cs:line 20
What do you reckon I need to do to get Sonarr up and running again? Thanks!
