Sonarr not showing downloaded shows
2.0.0.4753
OS: Windows 10
((Debug logs)):
So I switched to a different PC, and ever since then something hasnt been right. I am pretty sure I copied my settings exactly to the new one but its not acting right. I have a bunch of series that are showing 0/XX downloaded but in my downloads folder where they are I have a bunch of them. Say 15 out of 23 are there. But in Sonarr it shows 0/23. That and I cant get them to create their own folder when they download anymore. Any help would be awesome!
From the logs: Root folder 'E:\Downloads\' was not found.
Is that a local disk or a remote share?
Did you need to change that path after switching systems?
Where it goes isnt even to E:, I have it going to H: which is an External HD. Where do I go to switch the E: part that it keeps saying?
NM Found it when I go into Add Series.
Path is an ancestor of an existing path is what I get when I try switching them all to H;\Downloads\
Check the paths for each in the Series Editor and post ((debug logs)) again if you’re having issues still.
