Sonarr not searching for anime correctly
Sonarr version (exact version): 2.0.0.4230
OS: W10
Description of issue: This is a bit of an odd one. Sonarr previously worked perfectly for me. However, I refreshed my windows install the other day and it now refuses to search for anime correctly. I’m using oznzb, drunkenslug, and usenet crawler, the same indexers I was using before. I have them set to search 5070, and I have the series set to anime.
As an example, I’ll use Re:Zero -Starting Life In Another World-, as that was one of the series that sonarr was working just fine with before and fetching correctly every time a new episode came out. Searching for episode 15, which aired a week ago and does ofc already have files up on usenet, I get this: http://i.imgur.com/r9Thdnb.png. A quick hop over to oznb, however, yields this: http://i.imgur.com/PRFFOEN.png. Those are clearly mostly releases that should have been picked up by sonarr. A week earlier, they were and the episode was fetched just fine, however now sonarr just doesn’t see them. Anyone have any idea where I could have gone wrong?
I’m getting dozens of valid hits from drunkenslug and oznzb on a manual search for episode 15.
re:zero works fine for me.
make sure you have anime turned on in your indexers, category 5070 (advanced settings). and have the series type set to anime.
