Mono version (if Sonarr is not running on Windows): 6.12.0.182
OS: Docker / Unraid 6.9.2
Debug logs: https://pastebin.com/PqptSrFc (trace log for specific file)
Having an issue with replacing episodes with new copies. If it’s the first time an episode is grabbed, Sonarr imports it from QBit without issue, this error is only occurring when it tries to replace an existing episode, and it doesn’t happen with every episode either, some are replaced without issue, while others get the Destination Already Exists error. The mappings work fine as far as I am aware, since new episodes import without issue.
Specific error is NzbDrone.Common.Disk.DestinationAlreadyExistsException
Permissions Unraid for affected files are
previous file: 666 nobody users
new file: 666 nobody users
Permissions from within the Sonarr Docker container for affected files are
previous file: 666 abc users
new file: 666 abc users
I also ssh’d into the docker itself, and manually ran cp to copy the new file over the old file, and it worked without issue, so I don’t think it’s a permission issue either.
I did try googling for an answer, but couldn’t find anything that fit the problem I’m experiencing, so trying here to see if anyone has any ideas.
