3.0.5.1144.r02:
ASUSTOR NAS (if Sonarr is not running on Windows):
OS:
**System.ArgumentException: Requested value ‘Docker’ was not found.
at System.Enum+EnumResult.SetFailure (System.Enum+ParseFailureKind failure, System.String failureMessageID, System.Object failureMessageFormatArgument) [0x00023] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at System.Enum.TryParseEnum (System.Type enumType, System.String value, System.Boolean ignoreCase, System.Enum+EnumResult& parseResult) [0x0017a] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at System.Enum.Parse (System.Type enumType, System.String value, System.Boolean ignoreCase) [0x00010] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at NzbDrone.Core.Configuration.ConfigFileProvider.GetValueEnum[T] (System.String key, T defaultValue, System.Boolean persist) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Configuration\ConfigFileProvider.cs:220
at NzbDrone.Core.Configuration.ConfigFileProvider.get_UpdateMechanism () [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Configuration\ConfigFileProvider.cs:204
at NzbDrone.Api.Config.HostConfigResourceMapper.ToResource (NzbDrone.Core.Configuration.IConfigFileProvider model, NzbDrone.Core.Configuration.IConfigService configService) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\Config\HostConfigResource.cs:43
at NzbDrone.Api.Config.HostConfigModule.GetHostConfig () [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\Config\HostConfigModule.cs:52
at NzbDrone.Api.REST.RestModule1[TResource].<set_GetResourceSingle>b__38_0 (System.Object options) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\REST\RestModule.cs:141 at (wrapper dynamic-method) System.Object.CallSite.Target(System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func
2<object, object>,object)
at Nancy.Routing.Route+<>c__DisplayClass4.b__3 (System.Object parameters, System.Threading.CancellationToken context) [0x00049] in <63c44d6f8d7e4f339a987bf9eb94d931>:0
**I am logging in and when i click onto settings it just keeps refreshing and does not allow me to configure any indexers.
Currently i have the Sonarr V3 beta also on the nas which works fine so i am not sure why the new version is not working. Do i need to delete the beta first?**:
