Sonarr not postprocessing with torrents and transmission
Sonarr version (exact version): 2.0.0.4146
Mono version (if Sonarr is not running on Windows): 3.2.8 (Debian 3.2.8+dfsg-10)
OS: OSMC Raspberry pi 3
((Debug logs)) (posted to hastebin or similar): http://hastebin.com/ojuzivonir.tex
Description of issue: I have managed to set up torrentday with sonarr thanks the jacket. Sonarr can find and download torrents no problem. However, it doesn’t sort the downloaded torrents into show and series folders.
I have my transmission download folder set as: harddrive/downloads
I use the category tv in sonar. Sonar places the torrent in harddrive/downloads/tv but doesn’t sort it; for example, harddrive/downloads/tv currently contains “Veep.S05E07.720p.HDTV.x264-KILLERS”
Any help would be much appreciated.
We need these logs.
added the debug log but don’t see any errors
I think it could be due to the torrents containing a sample.
Thats not a debug log, it only shows info level logs, you need to enable debug logging in settings and since this is a problem on import the logs need to show the import process.
That doesn’t matter, the sample file is ignored.
Sorry, updated it there.
Is there a video file in that folder thats not a sample? or are the contents RARed? The only thing I see being processed is the sample file.
Yeah they are RARed, but I have a unrar installed. ie I can play the downloaded file in kodi.
Ahh that explains it, RARed content is not handled automatically, it will need to be unrared first.
Any tips on how to do this? Sickrage did it automatically, if It is too hard to sort out I’ll probably go back to sickrage.
Not sure, it would require the client being able to run a script on completion of the download.
Back to sickrage so, seems like an obvious feature to have.
Its on the list, but so are a ton of other things.
Ill try sonarr again in future so!
