Hi folks,
just started using Sonarr. I have it connected to Transmission running on my WD My Cloud NAS. My files are also located on said NAS. I was able to make Sonarr finding the files by setting the service to use my login, not system. Sonar was able to atuomagically add the series to my Transmission queue, however, it was not able to move the files after they were done. Here is the log
DownloadMonitoringService Couldn't process tracked download The.Leftovers.S02E05.720p.HDTV.x264-KILLERS[rarbg]: value [/mnt/HD/HD_a2/Public/Transmission/The.Leftovers.S02E05.720p.HDTV.x264-KILLERS[rarbg]] is not a valid Windows path. paths must be a full path eg. C:\Windows Parameter name: path
ArgumentValidator value [/mnt/HD/HD_a2/Public/Transmission/The.Leftovers.S02E05.720p.HDTV.x264-KILLERS[rarbg]] is not a valid Windows path. paths must be a full path eg. C:\Windows
How can I fix this? Transmission running on the WD uses *nix path syntax (which really sux when controlling remotelly) but that’s how it works.
