Sonarr version (exact version): 3.0.9.1549 ( 3.0.9.1549-ls170 by linuxserver.io)
Mono version (if Sonarr is not running on Windows): 6.12.0.182
OS: Synology DSM
Debug logs: [Error] DownloadedEpisodesImportService: Import failed, path does not exist or is not accessible by Sonarr: /downloads/Breaking Bad S01. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
Docker-compose file:
version: '3.9'
services:
################ SONARR ################
sonarr:
image: lscr.io/linuxserver/sonarr:latest
container_name: sonarr
environment:
- PUID=1034
- PGID=100
- TZ=${GB_TZ} # timezone, defined in .env
volumes:
- /volume1/docker/sonarr:/config
- /volume1/media/animes:/data/tv/animes #optional
- /volume1/media/series:/data/tv/series #optional
- /volume1/media/torrent:/data/tv/downloads #optional
ports:
- 8989:8989
restart: unless-stopped
network_mode: bridge
############### JACKETT ################
jackett:
image: lscr.io/linuxserver/jackett:latest
container_name: jackett
environment:
- PUID=1034
- PGID=100
- AUTO_UPDATE=true #optional
volumes:
- /volume1/docker/jackett:/config
- /volume1/media/torrent:/downloads
ports:
- 9117:9117
################ DELUGE ################
deluge:
image: linuxserver/deluge:latest
container_name: deluge
environment:
- PUID=1034
- PGID=100
volumes:
- /volume1/media/torrent:/downloads # downloads folder
- /volume1/docker/deluge:/config # config files
ports:
- 8112:8112 #web UI
- 58846:58846 # bittorrent daemon
restart: always
############# FLARESOLVERR #############
flaresolverr:
image: ghcr.io/flaresolverr/flaresolverr:latest
container_name: flaresolverr
environment:
- LOG_LEVEL=info
ports:
- 8191:8191
Sonarr does not move any completed files after Deluge downloaded them.
I’m pretty sure about my permission settings (prove me wrong I’m begging), after running my docker-compose command I did this :
sudo chown -R docker:users /volume1/media /volume1/docker
sudo chmod -R a=,a+rX,u+w,g+w /volume1/media /volume1/docker
And I correctly set PGID and PUID for my docker user.
So I was able to select root folders with sonarr (without valid permission I wouldn’t be able to) :
I’ve made the choice to name my host folders and my dockers folders differently so I can debug more easily (don’t know if it’s a problem, since they’re just mounted folder), so for my host, processing/complete files will be in volume1/media/torrent and in /downloads for my dockers (deluge, jackett and sonarr, see my docker-compose) :
Deluge config : (I’m not using incomplete/complete folder)
Jackett config :
What I do when I want to get a show :
When I look at my TV show folder (here breaking bad S01) the owner is docker, the same user that’s running sonarr.
If we look at the error :
It gives /downloads/Breaking Bad S01 and I’m not sure what the /downloads folder is.
I know that /volume1/media/torrent (host), /downloads (for deluge) and /data/tv/downloads (for sonarr) are the same folder. But what if /downloads without /data/tv was unknown for sonarr ?
I’ve been trying for weeks, have read a bunch of tutorials and have reset my nas a lot in order to always start fresh and it’s still not working…
Any help is appreciated ! I’ll be happy to give you more info and sorry for my poor english.
